I started digging to level ground for my 27' round AGP and it started raining. It has been several days now and the ground is a muddy mess. My question is after it dries and I set the pool up, if it rains again will the pool shift or sink in spots? Should I pad up the area with crushed limestone? The area is on top of a hillside where the water can be easily drained off but the ground is so wet from raining non-stop and the pool area now is somewhat level allowing the water to sit in puddles. Or will it be OK and when it dries and pool is set-up will the weight of the pool water keep the area packed enough where water will just run beside it?
