Thread: Questions about a new propane heater.
    May 2011
    Kootenays, BC, Canada
    Default Questions about a new propane heater.
    Hi all,
    Thanks for having me and I hope I can contribute something to your forum.
    I'm about to purchase a new propane heater for my 16x32' inground pool. It will replace a 25 year old Laars Teledyne 250 that has finally expired.
    I'm looking at a Hayward H200P1 Millivolt and have a couple of questions...
    1. I'm at 3100' elevation. Is it really necessary to have high altitude jets? One supplier suggests it is and another says, at this level, it's not necessary. i don't know if the Laars had them.
    2. Is there an advantage/disadvantage to going millivolt vs electric? I have a power switch for the pump close to the heater. My Laars was a millivolt.
    3. My heat requirement calculations bring me to the 200,000 btu model and the 250,000 btu model is almost the same price. Are there energy savings with one or the other? ( I also have a supplemental solar system)
    4. Where are Hayward heaters made? I'm in Canada and will be buying in Montana, so if they're made in North America, I won't have to pay duty.
    Thanks for your help.
    Scott
    May 2011
    Default Re: Questions about a new propane heater.
    I bit the bullet and bought a Hayward Hayward H200FDP Low NOx unit. The fan eliminates the need for re jetting until something like 7500 ft. No duty, either.
  1. Using a heater with a small (barbecue) propane tank?
    By stualden in forum Pool Equipment & Operations
    Last Post: 11-05-2011, 06:08 PM
  2. new heater questions
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 06-19-2010, 01:57 PM
  3. Need propane heater recommendation
    By DanS in forum Pool Equipment & Operations
    Last Post: 08-15-2009, 11:57 AM
  4. propane heater replacement
    By vinouspleasure in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2008, 11:58 PM
  5. Heat pump vs Propane Heater
    By mmcguire in forum Pool Equipment & Operations
    Last Post: 07-27-2006, 03:14 PM
