Results 1 to 10 of 21
Thread: CH test reads 0?
    Default Re: CH test reads 0?
    Yes, and it does not work. Like I said before I was playing around with it and found that it worked with about 8-10 drops of the indicator and I cross checked the results with the Taylor kit I have a few times and it is pretty close that way.
    nc.
    Angry Re: CH test reads 0?
    I' am very puzzled,when I did the test a few day's ago,it did just what it supposed too.After reading the post again this morning I did another test,and wouldn't you know, it never turned violet?????
    We had a pretty good temperature drop and my water is only in the 40's,compare to the other day when it was in the 70's...
    Could that be a problem with it???I' am no Expert,and really have a hard enough Time to understand all the other stuff going on in the pool...But now I' am very confuzzeld...
    Ok,I had to check again before I post,and no it did not work,just like Waterbear said it took me 9 drops,and then it turned in more like a black grayish color????
    @Sisie5,I have the Instructions.....
    I will try to scan and post them
    Margit
    Southeast N.C.
    Home of the Monster Bugs!!!
    Orlando, FL
    Well I'm also quite confused. I just re-did the test, and it only took 2 drops to turn the violet color. And then it too 10 drops to make it blue, which means my CH is 500ppm. Hmmm.. The only difference is that the pump hasn't kicked on today, so the water has sat motionless in the pool for about 13 hours. Could that alter the tests in any way?
    Is 500ppm a bad thing? My TA is 60.
  1. Filter pressure reads zero
    By Jellybeanck in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 12:33 AM
  2. ph test phenol red reads 7.2 then jumps to 7.5 !
    By maxhiller in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-11-2007, 12:42 PM
  3. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  4. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  5. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
