Results 1 to 10 of 28
Thread: chlorine levels
    Apr 2011
    virginia
    Default Re: chlorine levels
    The epoxy story is believable, but maybe doesn't explain it all...
    If it cleared up some initially, then got to a hold point, and the cloud really is sand/epoxy crud, I would guess initially you also had algae as part of the mix and killed it, and left now with just the other mess.
    If it really is epoxy flakes and sand, it should filter out
    May 2011
    centralcalifornia
    Default Re: chlorine levels/algae or something else?
    i was thinking the same. must of been something else in the mix that was killed off with chlorine.
    i also asked if this stuff should be filtering out. he said some may but some may filter through because so fine. i really dont have big flakes floating around, but just that light colored dust cloud ..that can be white in color too. i imagine is the actual plaster residue coming up when i brush. kind of makes me think i'm damaging the floor by brushing.
    but even if all this stuff on the pool floor is vacuumed or filtered out, when i brush again, the brush will brush more of this stuff off the pool surface because it's exposed????? so until i replaster and paint over to protect the surface, then as long as i brush i will always be scrubbing this stuff up??
    thats what my understanding was.
    i have a pool blaster vacuum and the finest filter cloth that was made for that vacuum. i know it's not fine enough. already tried vacuuming with it and i see the white stuff pass right thru the cloth and back in the water. i will try to line the inside of the filter cloth with a nylon panty hose see if i can catch some of the stuff.
    May 2011
    centralcalifornia
    i poured 4 lbs of cal hypo granular chlorine into pool last night. this morning right on the areas that i poured granules there was this whitish clouds setting on the pool floor. look just like what i was allgedly dealing with (brownish dust deposits) during this posts. so i concluded that: this same stuff i was trying to get rid of was being caused by the same chemicals i was using to get rid of the stuff; at least by in large part.
    can some one shed any light on the reaction that cal hypo would have on a plaster pool; plaster that is fading..would this whitish cloud be something to be expected. not all over the pool floor, but just on those areas where the granules settled. looks like the residue left behind by the granules...dont have my kit yet to get other chemical readings but cl is over 5 (dark yellow) and ph about 7.5-7.8. cl was about 1 when before i poured the granules last night.
    thanks.
    Apr 2011
    virginia
    I'm not sure- maybe Chemgeek or waste will have an answer (or one of the others)
    Cal-Hypo should usually be pre-dissolved in a bucket of pool water and then when added to the pool by pouring over a return flow with the pump running, any residue should be swept with a pool brush. You do not want to add concentrated chemicals quickly in one place since some of them can settle to the bottom and cause problems. You are fortunate you have a plaster pool because with a vinyl pool such settling of Cal-Hypo could have bleached the liner.
    If this white powder is easily brushed away, then it's undissolved Cal-Hypo. If it doesn't dissolve with circulation, then it may be residue from the Cal-Hypo -- basically filler -- which is probably not harmful, but is annoying and yet another reason to use chlorinating liquid or bleach instead of Cal-Hypo, or at least to use another brand.
    May 2011
    centralcalifornia
    so i heard (dissolve solids in water first before pouring in). and all this time i was trying to get rid of it as i poured 8lbs at a a time thinking it was something else...now i know. thanks.
  1. Can't keep chlorine levels up
    By resapre in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-13-2012, 05:37 PM
  2. Can't keep chlorine levels up
    By cbednara in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2012, 04:53 PM
  3. Need Help with Chlorine Levels
    By stateroaddog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2008, 09:09 PM
  4. Low Chlorine Levels
    By BigButz in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2007, 08:42 AM
  5. SWG and chlorine levels
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-17-2006, 04:01 PM
