When you originally make a post, it goes into a queue for one of us mods or Ben to look at, and won't show up on the forum until we approve it. Sometimes it takes an hour or two, but between the 5 of us, somebody is usually on the forum most all day. I deleted your other duplicate post.
IN a 20K pool, each 2 1/2 quarts of 6% bleach will raise your FC by roughly 2 ppm. Most of us use the regular, generic Ultra bleach from WalMart.
You can do a partial drain and refill with fresh water in order to lower your CYA. Just don't drain too much at one time so that you don't float your pool.
