Newbie here - Hi!
Just had my 25 yr old gunite pool renovated this week - plastered yesterday, filled in the afternoon, brushed twice already. I had the water tested just today - they told me that I need to get to 300ppm of total Alkalinity (?!?!) - now in order to do this I need to add 94 lbs of a certain chemical in order to get there (Bioguard) - then maintain the Ph by adding Muriatic Acid 1/2 gallon at a time over the next year (again ?!?!) - also need to add scale inhibitor (this actually makes sense) - the pool was here when I bought the house so I'm new to a fresh start like this - the water is chlorinated and when they tested the Ph the water turned bright pink... does this sound right? 300ppm of total Alk?![]()
Dave
Wakefield, MA
davecastine@gmail.com
. I believe you are simply guessing at what to do to your pool. Do you mean test strips when you say "sticks"?Dave, they are worthless.
THANKS stand by...
