Thread: Top diffusser for hayward s200 fiter
    Apr 2011
    Default Top diffusser for hayward s200 fiter
    What is the purpose of the top diffusser....mine is cracked what symptoms would it have on the filter...also i need to replace it what are the steps in removing it,can it be done thru the small dome or do i need to take the filter apart...Ty in advance
    Honesdale PA
    Default Re: Top diffusser for hayward s200 fiter
    That diffuser does exactly what it's name implies. Diffuses the water, sort of a spray, over the top of the sand. Here is the link to the manual
    http://www.hayward-pool.com/pdf/manuals/manual23.pdf
    and from what it says the top diffuser can be removed through the access dome.
  1. Replies: 14
    Last Post: 07-16-2013, 02:10 AM
