Hello - I wish I would have found you guys years ago! I'm once again very dissatisfied with advice I'm getting at my local pool store - pretty certain I'm not going back again. I thought I had a better handle on the chemicals!
This is a water analysis report I got today:
Free Available Chlorine - 7 (high) Shocked 2 days ago, stabilized chlorine
Calcium Hardness - 190 (ok)
Cyanuric Acid - 100 (high)
Total Alkalinity - 100 (ok)
pH - 7.6 (ok)
Total Dissolved Solids - 600 (ok)
Phosphates - 200 (high)
So CYA and phosphates are high. I have an in-ground gunite, 28K gallons, some algae growth. And yes, I'm also using 3" stabilized tabs in 2 floaters. After some education today I see it's a mistake to use them AND stabilized granules for shock.
The same shop who sold me both stabilized products now tell me I need to drain the entire pool and refill to get rid of the CYA. Since they could not tell me how "much" over 100 it was, and that some writers say don't worry about a high CYA, others saying yes I need to drain and refill - I'm in chemical confusion again.
My specific questions are in regards to this CYA problem and what my options really are. And, also if this is a good time to switch to bleach chlorination, i.e. the BBB program. I'm getting sick and tired of the expense and see-saw I've been riding with these chemicals.
Anyone's help is VERY appreciated.
keith
