We recently purchased a home with a pool that was full of green muck. I have no pool experience, but after reading lots of the threads on this site relating to algae, I decided on a course of action... shock the pool hard and keep shocking and brushing and vacuuming until everything is gone.
My readings at the outset were
30,000 gal. pool
FC - 0
TC - 0
ph - 7.4
TA - 90
CYA - 45
I added 12 gallons of bleach after sunset this evening. A few hours later my ph was between 7.8 and 8.
Is it normal for the ph to rise significantly after adding bleach to shock the pool?
I added the prescribed amount of muriatic acid to combat the rise. Will the period of high ph make the chlorine less effective?
It is hard for me to tell what the FC/TC is right now because I only have a small oto test kit while I wait on the full kit to arrive by mail.
Thanks for any help you might be able to give!
