Thread: Cloudy water
    Default Re: Cloudy water
    I would think you could drain as much as 1/3 to 1/2 at a time without a problem--as long as there's at least 2-3 feet of water in the shallow end I think you're fine. Alternately, one of the other mods has posted a "sheet" method, where you take a large piece of plastic and pump from underneath as you refill from the top so that the pool basically stays full throughout the process.
    In order to shock the pool, you really need to be measuring the chlorine levels instead of just dumping "some" chlorine in and hoping for the best--your method may work sometimes in a hit-and-miss way, but to get reliable results you really need to measure your levels to keep them where they need to be and to get rid of the algae.
    You definitely need to stop using cal-hypo at this point, though--I suggest you switch to plain, generic bleach. How many gallons does your pool hold?
    May 2010
    I will go to plain bleach.
    A quick online calc shows my pool is 19,200. It's a free form that is 16'X32' with a 3' shallow and an 8' deep.
    Time to drain!
    In 19,200 gallons, each 1.5 gallon of bleach should raise your chlorine by 5 ppm. Each 1.5 quart should raise your chlorine by 1 ppm. (That's 6% strength).
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
