Your calcium hardness level is WAY too high and I'm sure is most likely the reason for your cloudy water. Your other numbers are ok except the TA is a little high which is also most likely adding to the problem. I'd be willing to be that you are shocking with cal-hypo and if so, stop. Just use plain bleach for your source of chlorine as it will not cloud the water. The only way to drop the calcium hardness reading is to do a partial drain and refill. Do NOT totally drain your pool. What type of pool is this?
