Results 1 to 10 of 10
Thread: Cloudy Pool after battling algae.
    Mar 2011
    Baton Rouge, LA
    Default Re: Cloudy Pool after battling algae.
    The forum has been beneficial to me so far...only makes sense to support it.
    I'll give it a few days for the filter to do it's work. Is there a way to tell if the filter is doing a good enough job? Currently the filter pressure goes from 12 psi to 22 psi in around a day or a day and a half. While backwashing, the water looks pretty dirty and takes around 2 minutes to clear up. It seems normal, but just wanted to make sure.
    On the CYA reading, I could not get a reading last night on my kit. But when I went to the pool store the other day, they had a pinpoint testing machine that said it was 9 ppm. I realize that I need to add some CYA. The pool store folks said that while adding I shouldn't backwash for a few days to give flakes a few days to dissolve. Considering that I have to backwash every day or so now because of the algae clean-up, should I just wait on adding CYA? I was thinking that perhaps adding the CYA to a filter sock might allow me to add while still backwashing?
    * EDIT *
    My calcium hardness levels are a bit low. 134 was the pool store test. I didn't bother testing them last night because from what I understand I really don't need to worry about them because I have a liner pool.
    Smile Re: Cloudy Pool after battling algae.
    Welcome to the forum!
    Don't add the CYA until the algae battle is finished! (you'll end up sending a good portion of it out the backwash) If you want, you can put the CYA in a sock and hang it in front of a return, but I think you're better off waiting until the algae problem has been dealt with.
    As Watermom (Hi Mom ) said, the flocs and clarifiers will only confuse your issue.
    A little POP (Pool Owner Patience) is required here - I doubt you plan on swimming tomorrow, so take a few days and get rid of the algae completely first
    Mar 2011
    Baton Rouge, LA
    Thanks for the advice . I'm applying some patience and it seems to be paying off as I get all the junk filtered out of the pool. How often should I be brushing the pool? Is it better to vacuum the accumulation at the bottom or just brush it into the water again?
    You should be brushing the pool at least daily. As far as the stuff on the bottom, vacuuming it, if you can vacuum to waste, will get rid of it much quicker than brushing it up into the water. If it's big enough, you might also try a fine-meshed net to scoop some of it off the bottom to get it out. If all else fails, then brush it up into the water. The filter will eventually get it, but it will take a good bit longer.
    Something you might try is adding a little DE powder to your sand filter. Many of us do this and it helps your sand filter to filter out things that are a little smaller than it normally could. It is a little tricky getting just the right amount. You can read more about it at the following link. Just something else to consider. Glad the pool is starting to look better!
    http://www.poolforum.com/pf2/showthread.php?t=3742
    Mar 2011
    Baton Rouge, LA
    Going to try this today! Thanks Watermom
    Apr 2011
    virginia
    [QUOTE=Jbonnette;69317]
    QUOTE]
    The fact that your pressure is increasing, along with dirty water during backflush, tells you the filter is working- the increase pressure is due to clogging with debris, which you then rinse out during backwash.
    Note, a slightly dirty filter works better than a clean one, as the partial clogging also makes smaller holes in filter media to catch more crap- partial backwashes more frequently will often reduce total time cleaning the cloud out of the pool, but at end do a double duty backflush to make sure no residue left in filter; decaying algae can give more "food" for future algae, so you want all that crap out!
  1. Battling algae with a cartridge filter
    By McDug in forum Dealing with Algae & Slime
    Last Post: 05-18-2012, 05:16 PM
  2. Battling high alkalinity in new pool
    By MadCrammer in forum Dealing with Alkalinity and Calcium
    Last Post: 07-19-2011, 01:58 AM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Help - major algae now cloudy pool
    By xoroniox in forum Dealing with Algae & Slime
    Last Post: 04-17-2006, 12:33 PM
