Results 1 to 10 of 14
Thread: DE in pool
    Mar 2011
    Cibolo, Texas
    Unhappy DE in pool
    I know this has probably been addressed before but I have been away from this forum for a while.
    I have a Pentair FNS plus 48 DE filter system. lsat year I was getting DE on the bottom at the end of the season. I didn't worry about it to much until I backed washed for the winter(my pool runs year round in San Antonio) due to pressure. When I backed washed my pressure was still up so I tore apart the filter to do an extensive cleaning on it.
    While doing so I found the DE problem was my Internal Air Bleed Assy. was completely disinigrated so I replaced it with a new one part #190091 which is a screen type different form the one before. I also cleaned my filters look wich looked OK until I uncovered the pool for the season and had DE on the bottom so I vacummed and it kept coming back but notas heavy.
    I spoke to my local pool store and the said to check the grids real good and for cracks in the manifold. While doing the cleaning I inspected everthing and could not find anythin wrong with the grids or manifold. So I pur everything back together replaced the o-ring on the tube to the manifold and put everything back together. I also look at the multi port valve gasket which aslo seamed to be OK.
    I am still getting DE into the pool and do not know what else I can do. My wife thinks if I keep vacumming what comes in becuase of the stirring and vacumming it will eventially go away, but I do not think so because it should be captured in the filters and not be reurning. I feel it may be the new screen type breather but it is a factory replacement. Has anyone else had this issue after replacing the Air Bleed Assy. or have any ideas on what is causing the DE to come into the pool??
    Default Re: DE in pool
    Welcome to the forum!
    I'll trust that the grids are fine and the multiport gasket is good.
    How about the o-ring that seals the manifold to the return pipe? Also, are the 'fins' on the top of the grids whole and fully seated in the manifold, AND the fabric all the way up and, at least, to the manifold?
    We're running out of places for DE to get through the system, so I hope it's one of the things I mentioned
    Mar 2011
    Cibolo, Texas
    yes I checked and did all those things. Maybe its the way I am vacumming? How should the skimmer covers be when you have two skimmers?
    I trun one to close off the top hole and plog the center hole on the cap. The other I turn to close of the top whole on the skimmer and put the hose in the top of the cap?
    Without one one of above things being wrong, the way you vacuum doesn't affect DE going back into the pool
    Please check over all the things discussed here - mayhaps you missed a little something somewhere
    That's the best I can offer
    Mar 2011
    Cibolo, Texas
    Thanks,
    Thats what I paln to do, I don't know what else it could be.
    Mar 2011
    Cibolo, Texas
    Well today is the day I tear it all apart and try to remedy the problem again.
    I have pretty much decided if I cannot resolve the issue I may replace the filter. I love the DE becuase it cleans so efficiently but I can't deal with the issue of it getting into the pool evrytime I do a filter cleaning.
    I know there are pro,s and con's for all three but I would like to get some feed back on the type and brand I should go to if I switch?
