I have a new pool, just over a year old, and having some problems with PH. Here's the Stats
850,000 Gal, 55 meters long, 25 yd across, and from 7 1/2 feet to 13 feet deep. It Pumps 2700 gpm, with 6 sand filters inline, UV filter, Acid Feeder, co2, and a Pulsar4 chlorine tablet feeder.
The problem I am having is that our automated chemical system is set to keep PH at 1 7.3. It does its job, but I keep getting different readings from the water in the pool. I get a 6.8 reading on the shallow end, and a 7.0 on the deep end. I am wondering If I need to change what our chemtroller is set to to make up for the difference.
Other numbers:
Alk: 60
TC: 3.0
Ca: 520
Also, the company that built the pool recommends a 7.3-7.4 PH for our pool, with the diamond-brite bottom, and bulkheads
