Thread: pvc unions
    May 2010
    Default Re: pvc unions
    Do you have solid PVC pipes? if so you can use glued fittings.
    Quote Originally Posted by britinusa View Post
    I fear you mistunderstood. The OP is talking about the threads that screw into the salt cell.
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    If there is enough room on either side of the cell, couldn't you just install two standard unions, one on each side? That would allow you to open the line at the (new) outer unions and remove the cell with it's unions and all, and replace the whole assembly with a pipe.
    Honesdale PA
    Never dealt with salt syatems but if you just shut the system down I would think the water chemistry wouldn't be affected. Therefore why bother removing the cell?
  1. Home DepoPVC unions?
    By neato5oh in forum --cleanup--
    Last Post: 10-30-2012, 01:20 PM
  2. Hayward AG Pool pump unions larger?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 04-06-2009, 05:19 PM
