Results 1 to 10 of 15
Thread: Pool Opening - PS234 Test
    Maine, USA
    Default Re: Pool Opening - PS234 Test
    NP, I appreciate the help, no apology needed!!
    Hmm, well I stepped outside to add the borax to the skimmer when I realized that I was in the middle of vacuuming and backwashing every 5 minutes or so. Even if I'm not vacuuming, I'm still having to backwash a lot because of the "stir up" I've caused. IOW, I didn't want to add the borax to the skimmer in case I needed to backwash in a few. So, I just scattered it around the pool (it seemed to dissolve fairly quickly - a few 'chunks' fell to the bottom, but I've ceased vacuuming for now until the PH is up). I hope that's OK? So far the pressure is maintaining a 15 psi, not too bad for now ( just don't want to backwash the borax ).
    I'll check chlorine and PH levels in a few hours and report back.
    Regards,
    Ron [ muvipix.com ]
    Maine, USA
    Quote Originally Posted by Watermom
    It is fine to broadcast the Borax. However, it is also fine to add it to the skimmer. It will dissolve immediately and quickly be dispersed in the pool water, so even if you do have to backwash, you won't lose it. (Cya doesn't dissolve immediately, it sits in the filter for several days dissolving slowly. So, it does get backwashed out, but the same is not true for Borax.)
    Thank you ... good to know!
    New numbers a few hours later (after 2 lbs borax) -
    PH - 7.2
    FC - 10 (I think we're killing some stuff)
    CC - @ .5 (maybe a bit less now - makes some sense)
    Shall I just run the pump all night and check chlorine in the AM?
    And, should I raise the PH a bit more? ie, 1 more lb of borax?
    Then I'll test all numbers again mid-day tomorrow. I won't budge until I hear something here.
    Regards,
    Ron [ muvipix.com ]
    If it were my pool, I'd add a little more Borax and aim for 7.4-7.6. I also think, if it is practical for you, that I would retest chlorine later tonight and add more bleach to raise it back up to 10 and then do the same thing again in the morning. The key to killing algae is to sustain the high chlorine reading and not let it yo-yo up and down. While fighting algae, we usually advise testing 3x a day and each time raising the cl back up to shock level - which in your case, for now, is 10ppm. Run the pump 24/7 while you are working to clear the pool.
    Maine, USA
    OK, I checked my numbers this morning and my PH shot up for some reason
    FC - 14
    CC - < .5
    TC - @14.5
    PH - > 8.2 ?
    Alk - 110
    Maybe the bleach added the extra PH? Should I apply a bit of muriatic acic? If so, how much? A quart to start?
    The water is looking a little better, but I still need to vac some more.
    Regards,
    Ron [ muvipix.com ]
    Double check your ph reading. If it truly is that high, then yes, you should add some muriatic acid.
    Maine, USA
    Thanks again. Got it down to between 7.5 - 7.6.
    FC - 11
    CC - < .5
    TC - @ 11.5
    Alk - 110
    Still filtering/vacuuming. Even when I'm not vacuuming, I have to backwash every 20-30 minutes or so. Lots of dirt.
    Thanks for everything thus far!
    Regards,
    Ron [ muvipix.com ]
    Maine, USA
    PH - 7.6
    Alk - 90
    FC - 8.5
    CC - 0
    TC - 8.5
    Took cover off:
    10 minutes later with initial 'shock':
    Day 2:
    End of Day 2:
    10 minutes ago (day 3 - AM) after vacuum/brush
    This is the final:
    Even a drastic difference from the last one above. All of my numbers are perfect (MO) and I'm using up some pucks from last season to start getting my CYA up. Other than that, it was bleach (@7 gal.) and 1 box of borax for my opening 'stuff'. A far cry from past years 'kits' from the local pool store ... done with that
    Thanks everyone! Couldn't have done that without this forum or the PS234!
    Regards,
    Ron [ muvipix.com ]
  1. opening pool - water test results
    By mike_311 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 10:55 PM
  2. Opening the pool a little early. Here are my test results so far.
    By bri3180 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-19-2013, 01:24 PM
  3. Opening pool test results
    By GregP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-18-2012, 11:37 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. first pool, first test with the ps234
    By dhale63 in forum DPD-FAS based testing
    Last Post: 05-08-2006, 11:12 PM
