Re: Pool Opening - PS234 Test
Watermom
It is fine to broadcast the Borax. However, it is also fine to add it to the skimmer. It will dissolve immediately and quickly be dispersed in the pool water, so even if you do have to backwash, you won't lose it. (Cya doesn't dissolve immediately, it sits in the filter for several days dissolving slowly. So, it does get backwashed out, but the same is not true for Borax.)
Thank you ... good to know!
New numbers a few hours later (after 2 lbs borax) -
PH - 7.2
FC - 10 (I think we're killing some stuff)
CC - @ .5 (maybe a bit less now - makes some sense)
Shall I just run the pump all night and check chlorine in the AM?
And, should I raise the PH a bit more? ie, 1 more lb of borax?
Then I'll test all numbers again mid-day tomorrow. I won't budge until I hear something here.
Regards,
Ron [ muvipix.com ]
