Results 1 to 10 of 15
Thread: Pool Opening - PS234 Test
    Maine, USA
    Default Pool Opening - PS234 Test
    FC - 21
    CC - .5
    TC - 21.5
    PH - 6.8 or < (yellow)
    Alk - 60
    Cal - 40
    CYA - 0
    Temp - @40
    IG, Vinyl liner @22,000 Gal. W/chlorine that high, should I try to correct everything now? And I have a LP heater so I guess I should get the Cal. up as well?
    We had a few problems last year with algae blooms and PH/Alk all over the place. We've used the pucks ( 3B's now ) for chlorination, so I expected CYA to be at least a reading, but nothing. I have some pucks left over ... shall I throw them in there (or get the PH up first?)? I had a mesh cover and although the pool is filthy, it doesn't look that bad algae-wise. On to vacuuming...
    Any tips on where to really start would be appreciated, thanks!! I know it needs work.
    Default Re: Pool Opening - PS234 Test
    First, raise your pH, now, with borax.
    Second, make sure your pH is up, to at least 7.2. If it's not, keep going.
    Third, get your pH to 7.2 - 7.4, and don't stop till you get there.
    After you finish that, you can worry about other levels. Meanwhile, filter 24/7, and brush and vacuum till you're all clean. And, if the chlorine drops below 5.0, add bleach in the evening to get it back up to 10 ppm or so. Don't use tabs; don't mess with other stuff; don't try to fix everything else, till the pH is up and the algae gone.
    Good luck,
    Ben
    PS: You need to get your pH up! A reading of 6.8 means that it's 6.8 or LOWER, not that it's exactly 6.8. It may be 4.5!!
    PPS: If you add borax, and nothing seems to happen, add another box. Add slowly, via the skimmer, and wait 2 - 4 hours between additions. If you think you are using too much borax, and that your testkit's not working, sprinkle a pinch of borax into your pH water sample: if it turns purpley, your test is fine. So, add another box of borax.
    duraleigh Guest
    Hi, Rhosk,
    What strikes me as needing work just might be your test results!!
    If your results are good, you must've put a really big dose of Cl into your pool within a couple hours or less of the test. Otherwise your Cl would be ZERO since you have no stabilizer. Confirm that's the case....I'm gonna' assume it is.
    Assuming the above is accurate, your Cl will be close to zero this evening. I would get some CYA right away, I would get some 20 mule team borax as well.
    The sooner you get your stabilizer and borax in the pool, the better your pool will hold the Cl during the day. (again, assuming CYA of zero) Bring stabilizer up to around 30-40ppm and put enough borax in to get your pH up around 7.2 - 7.6.
    Then, bring your Cl back up to around 4-6ppm and keep it there as a maintenance level.
    All this advice is groundless if your test turns out to be different than what you posted....it's really unusual to test that much Cl in a pool with no stabilizer. Let us know
    Maine, USA
    Yes, I did shock first, should've mentioned that, sorry. In my (ignorant) mind, I assumed that I should get chlorine (bleach & 1 bag of 50%) in there right away (shock level --- or in my case --- or above).
    I have 5 boxes of borax. Thanks for the start-up step by step. I'll (slowly) get the PH back up (that's why I indicated 6.8 or less). And of course I trust the test kit - it's fantastic! More than I thought it would be. I'm used to test strips and pool store reliability ... no more!
    I have a lot of "grime". Algae may be mixed in there as well, but I'm having to backflush every 5 minutes or so and I'm only about 1/3 done vacuuming - whew. I don't think I like the mesh cover deal. Lets a lot of dirt through.
    Thank you very much for the prompt replies. Love this place
    PS, taking pics along the way too.
    duraleigh Guest
    Rhosk,
    Yeah, that makes sense. As always, Ben's info is the most pertinent. I overlooked the importance of getting the pH up out of danger as the first priority.
    Sounds like you're on your way to sparkling water. It also sounds like you've got a better grip on things than I gave you credit for.......the Cl of 27 threw me....Sorry!
    Maine, USA
    NP, I appreciate the help, no apology needed!!
    Hmm, well I stepped outside to add the borax to the skimmer when I realized that I was in the middle of vacuuming and backwashing every 5 minutes or so. Even if I'm not vacuuming, I'm still having to backwash a lot because of the "stir up" I've caused. IOW, I didn't want to add the borax to the skimmer in case I needed to backwash in a few. So, I just scattered it around the pool (it seemed to dissolve fairly quickly - a few 'chunks' fell to the bottom, but I've ceased vacuuming for now until the PH is up). I hope that's OK? So far the pressure is maintaining a 15 psi, not too bad for now ( just don't want to backwash the borax ).
    I'll check chlorine and PH levels in a few hours and report back.
    Regards,
    Ron [ muvipix.com ]
    Maine, USA
    Quote Originally Posted by Watermom
    It is fine to broadcast the Borax. However, it is also fine to add it to the skimmer. It will dissolve immediately and quickly be dispersed in the pool water, so even if you do have to backwash, you won't lose it. (Cya doesn't dissolve immediately, it sits in the filter for several days dissolving slowly. So, it does get backwashed out, but the same is not true for Borax.)
    Thank you ... good to know!
    New numbers a few hours later (after 2 lbs borax) -
    PH - 7.2
    FC - 10 (I think we're killing some stuff)
    CC - @ .5 (maybe a bit less now - makes some sense)
    Shall I just run the pump all night and check chlorine in the AM?
    And, should I raise the PH a bit more? ie, 1 more lb of borax?
    Then I'll test all numbers again mid-day tomorrow. I won't budge until I hear something here.
    Regards,
    Ron [ muvipix.com ]
    If it were my pool, I'd add a little more Borax and aim for 7.4-7.6. I also think, if it is practical for you, that I would retest chlorine later tonight and add more bleach to raise it back up to 10 and then do the same thing again in the morning. The key to killing algae is to sustain the high chlorine reading and not let it yo-yo up and down. While fighting algae, we usually advise testing 3x a day and each time raising the cl back up to shock level - which in your case, for now, is 10ppm. Run the pump 24/7 while you are working to clear the pool.
    Maine, USA
    OK, I checked my numbers this morning and my PH shot up for some reason
    FC - 14
    CC - < .5
    TC - @14.5
    PH - > 8.2 ?
    Alk - 110
    Maybe the bleach added the extra PH? Should I apply a bit of muriatic acic? If so, how much? A quart to start?
    The water is looking a little better, but I still need to vac some more.
    Regards,
    Ron [ muvipix.com ]
    Double check your ph reading. If it truly is that high, then yes, you should add some muriatic acid.
  1. opening pool - water test results
    By mike_311 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 10:55 PM
  2. Opening the pool a little early. Here are my test results so far.
    By bri3180 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-19-2013, 01:24 PM
  3. Opening pool test results
    By GregP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-18-2012, 11:37 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. first pool, first test with the ps234
    By dhale63 in forum DPD-FAS based testing
    Last Post: 05-08-2006, 11:12 PM
