Results 1 to 8 of 8
Thread: Sand Filter at 37-40 PSI (help?)
    Honesdale PA
    Default Re: Sand Filter at 37-40 PSI (help?)
    That noise from the pump when you were on the main drain was probably cavitation due to a blockage in the suction side. As Carl suggested, what happens when you're on the skimmer alone? It also isn't clear how long it took the pressure to rise from the normal 15-20 to pegged. Over a period of days or what? That could be a clue. Mark is right in that most pool pumps won't hit that pressure even when totally blocked, but could easily reach 30 or a little higher. The gauge is probably not totally shot since it still reads zero when off. For $10 you can get a decent one. And no, we never put together a troubleshooting flow chart. If any grass clippings got past the pump basket and into the sand filter, backwashing should clear it. You are using chlorine for sanitation aren't you? Reason I ask is Baquagoo can plug up a filter. We'll figure this out eventually.
    Hope this helps.
    BTW: Just a reminder for all when posting. The forum is popping up parsing errors more frequently now so use the 'ctrl C' to copy to the clipboard before posting your response or previewing it. Just in case you lose it. Saves retyping.
    Jun 2010
    Phoenix, Arizona USA
    Thanks for all of the great responses and pointers. Here's what is still going on...
    The gauge is now completely pegged. I had the pump off during a cold spell here, and while it was off, the gauge went to zero. But within hours of being back on, the gauge was pegged (over 60PSI).
    When I cut over to the main pool drain, no water pulls through into the pump. You can see there is no water in the filter cover and the pump starts making loud noise. When I cut back over to skimmer basket, it corrects.
    I have backwashed, rinsed, and reset the multiport valve to filter.
    My stabilizer is at 120 and minerals are very high. I am going to drain the pool and then see about taking apart the drain. After thinking about the components and the complete system, I think it's a clogged drain (or pipe) and possibly old/clogged/calcified sand in the filter. I think that starting here will get it going.
    joined 2010, new pool owner, old pool - 18-20,000 gallon pool, sand filter - trying to live BBB
    mas985's Avatar
    Pleasanton, CA
    It is impossible for the pressure to reach 60 PSI so it sounds more like a bad gauge. For some gauges, the maximum PSI is actually 30 PSI. Are you sure that it is hitting 60 PSI? If so, replace the gauge because it is not reading correctly.
    That means there is a blockage in the main drain line. Are you sure there isn't a plugged somewhere.
    Mark
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 10:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 08:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 12:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 08:58 AM
