Closed Thread
Results 1 to 8 of 8
Thread: Return line
    Dec 2005
    Denham Springs, Louisiana, USA.
    Default Return line
    One of my return lines sometimes blows out tiny bubbles. I don't know if air is getting in when I clean the skimmer, or from the polaris or what. Is this normal or should I have someone look at it?
    Casey
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Re: Return line
    Do you have a SWG? Mine does this after the SWG is on.
    Dec 2005
    Quote Originally Posted by Davenj
    Yes I have a Aquarite SWG. Will the air bubbles hurt anything?
    Dec 2005
    I'm going to have my husband check the pump and the o ring. Thanks for your help.
    Jersey Shore
    SWG bubbles won't hurt anything. I believe its hydorgen from the process of making chlorine.
    Dec 2005
    Casey
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Well mine always has tiny air bubbles in the return but thats due to my triopure ozonator.
    Does your filter have air in it? Mine has a trap with a clear cover just before the filter and if I get air in the system it shows up here.
    I doubt you could intruduce air on the pressure side so I'd check your O-rings around the filter.
    A suction side cleaner like the polaris will easilly introduce air to the system if you dont get all the air out of the hose first.
    Indiana.
    Probably the most common cause of return bubbles is a loose pump strainer basket lid or a bad O-ring on that lid.
Closed Thread
  1. Possible Return Line Leak
    By wddupree in forum --cleanup--
    Last Post: 01-06-2013, 11:43 PM
  2. Leak in return line...I think
    By DustinBrown in forum In-Ground Pool Construction and Repair
    Last Post: 06-27-2012, 05:24 PM
  3. Is one return line enough?
    By McDug in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2012, 12:45 AM
  4. Return Line Air Bubbles
    By rommulus in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-17-2011, 09:54 PM
  5. Return Line blocked
    By Bkirrane in forum In-Ground Pool Construction and Repair
    Last Post: 05-30-2010, 11:04 AM
