Results 1 to 9 of 9
Thread: Newbie, Dumbie, My pool Fizzes when you jump in
    Aug 2010
    Default Re: Newbie, Dumbie, My pool Fizzes when you jump in
    I am using test strips and they appear to be able to read down to around 6.6 ph The color is kind of between 6.8 and 7.2, if I had to favor one or the other via color I would favor 7.2.
    After it all started I tried a defoamer for a couple weeks, and that will for a day or so stop it.
    I tried clarifier once a week, for about 2 weeks. Did not seem to help.
    All products were from pool stores.
    I have been aerating via pointing the jets upward for the last 24 hours, after reading the interesting post on carbonates and it seemed to be helping a little bit as of tonight.
    The swim suits have not been washed in soap now for 2-3 weeks and no sun screen either for at least that long.
    I should mention we live near Minneapolis, MN so it is cool now, average daily temp around 60 to 65 degrees, and I kept the pool around 75 degrees.
    Thank you all for your help.
    Defoamer and clarifier? Stay away from them!
    You'll need a proper test kit, such as the Taylor K-2006 or K-2006C, but until then seek out the Walmart 5-way (or 6-way) drop test kit for about $15. It will give you a FAR better pH reading.
    If you can't find than, then buy a simple OTO drop test kit--the pH test should be better than strips. If you can find one that uses Taylor chems, that's better (I think that's what the Leslie's chain stocks).
    Aug 2010
    Thanks for everything.
    I have been aerating via upward pointed returns and it is better 50% better after about 48 plus hours. I am aerating mostly with the autocover on, it is in the 60s up here and I live in a forest.
    On the strips still reads 7.2, I suspect the pH was actually lower than I thought or strips read.
    I will check for the drop tests but next year will be buying the kits you all recommend for next year
    Thanx so much
    tasso
    At least get the OTO drop test kit now. It's about $7 usually and only has two tests: Chlorine (OTO test) and pH. You cannot trust the strips.
    I would only use either Hache or LaMotte brand strips and even they aren't very good. It's very hard to match the colors to the keys and even then, when compared to a drop test they are AT BEST, so-so.
    I know most men have a poorer color sense than most women and it's genetic. Color-blindness is common among men but a medical oddity among women, but I generally have a very acute color sense--even my wife admits I can detect variants in shades and tints better than she can (not by much, though--and only when I actually CARE ) but I have a devil of a time seeing subtle differences in the test strips.
    I mainly use them for a quck check of FC. If it's white I have none. If it's a watery purple I have some but probably not enough. If it's deep purple I have at least an FC of 10.
    This is why we do NOT recommend using them, preferring for new-comers to the B-B-B method of pool maintenance to use drop testing instead. Pool store clerks LOVE to argue with us, but they're the ones that push all kinds of useless and even damaging chemicals on you.
    Aug 2010
    Red face Re: Newbie, Dumbie, My pool Fizzes when you jump in
    I did the liquid drops and it was about the same 1 on the Chlorine and 7.2 on the PH. Overall is is better than before and not a big issue anymore. THANX for all the help.
    Now the Newbie Dumbie is going to close his own pool, look for my questions in that section, once I find that section/thread "closed it today" overall really was pretty easy
  1. Pool newbie
    By Limeybiscuit in forum Pool Equipment & Operations
    Last Post: 03-27-2017, 12:20 AM
  2. Pool Newbie
    By blazin in forum --cleanup--
    Last Post: 10-20-2012, 12:04 PM
  3. First pool, it's hot, want to jump in!!!!
    By Jake337 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-27-2012, 10:20 PM
  4. Jump rocks
    By Llpsmith in forum In-Ground Pool Construction and Repair
    Last Post: 07-22-2011, 01:10 PM
  5. Newbie with a Fox Pool...
    By mariner09 in forum Pool Equipment & Operations
    Last Post: 06-13-2006, 12:08 PM
