Thread: Feedback on my test numbers requested
    Default Feedback on my test numbers requested
    27,000 IG plaster pool
    I opened a week ago, shocked, tested had 0 CYA, low PH, low calcium, low alkilinity.
    I shocked, added borax, then calcium, then baking soda, then cya. As of today I have these test numbers:
    TDS 500
    CYA 34
    Tot CL 1.5
    Free CL 1.5
    PH 7.7
    tot ALK 96
    adj ALK 86
    tot hardness 98
    water is clear and blue. I think I'll add some bleach, but other than that are my numbers ok? Thanks in advance for your feedback
    duraleigh Guest
    Default Re: Feedback on my test numbers requested
    Good morning,
    Those are good numbers...especially since your water looks so good.
    Your CYA test should yield results like 20, 30, 40, etc.......not 34. If that's a pool store test, I would buy Ben's kit. You'll do FAR better testing your own water. Yeah, I'd keep my Cl up around 3-5ppm. Good work!
    thank you, I wasn't sure. This is only my 2nd season as a pool owner. everything I know I learned here last summer.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Quote Originally Posted by portlandpool
    tot hardness 98
    Dave S,
    Shouldn't this hardness level get up a little higher as he has a plaster pool?
    CaryB
  1. Pool Details (as requested)
    By Cybergy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-24-2012, 12:13 PM
  2. numbers from test
    By mrs.rainbow in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2011, 11:11 PM
  3. TF-100 first test results, requesting feedback
    By pbotz2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2010, 03:54 PM
  4. First test results need feedback
    By DMand in forum DPD-FAS based testing
    Last Post: 07-03-2006, 04:52 PM
  5. Got the new test kit. Here are the numbers. Tell me what to do.
    By rfreeman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2006, 05:18 PM
