Thread: solar heater
    Aug 2010
    ontario canada
    Default solar heater
    getting a solar heater for 18 ft pool in spring of 2011
    want to put it on the roof of my metal shed. good idea?
    here is what i need help with i have a 1 hp hayword pump aprox distance from shed is 30 ft
    top of shed aprox 8 ft
    will this work or is the distance to far
    Default Re: solar heater
    If you use large pipe, 2.5" or 3", to minimize friction losses in the pipe, then there should be no problem at all. I used to have 1 HP pump (now I have an Intelliflo VF) and have much longer runs from the pump to the house of around 60 feet and a higher roof of 12 feet and very long runs on that roof to 12 solar panels. Unfortunately my PB used 2" pipe and this is costing me around 30% more in electricity costs than it should as a result.
    Aug 2010
    ontario canada
    Smile Re: solar heater
    thx for the help
    Aug 2010
    ontario canada
    anyone got a preference on what one to buy and picks of the hook ups
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by gregc57 View Post
    Does this mean you have an AG pool? AG pumps can sometimes have a problem with lift. What is the model # of the Hayward pump?
    Mark
    Aug 2010
    ontario canada
    yes it is a above ground
    pump is a 1hp hayword model # not shure will look tomorrow as i have put it away in or storage closet from h as we refer to it
  1. Replacing Solar thermal and natural gas with Solar PV and electric pool heater
    By California Newbie in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 07:14 PM
  2. solar heater
    By alexstjo in forum Pool Equipment & Operations
    Last Post: 06-03-2011, 02:38 PM
  3. DYI Solar heater
    By jkoch in forum Pool Equipment & Operations
    Last Post: 08-02-2010, 02:08 PM
  4. solar heater
    By pkzmf in forum Pool Equipment & Operations
    Last Post: 06-16-2006, 04:13 PM
  5. Solar Heater ?
    By kevincad in forum Pool Equipment & Operations
    Last Post: 04-21-2006, 11:27 AM
