Re: Testing for salt
The Goldline salt tester (Goldline just puts their name on it) is about 100 dollars. You could easily wind up spending that (and more) by using test strips that are giving you faulty readings. I haven't used them, and really can't comment on them, other than reading threads here and elsewhere where the readings have been off, causing owners to over salt pools thereby requiring partial drain and refill (charges that could be saved by having an accurate salt tester). I've also seen threads here stating cons with the testers saying that, "But you have to calibrate them all the time". Iv'e had mine for years and have only needed to calibrate it once (you do need to check it often, but that is easy.) I have to check salt content all the time, so it don't make sense for me to use test strips. I understand that the price works out to about 1 dollar a strip. Too expensive for me.
4 out of 3 people have trouble with fractions.
Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
