onemsmom
After the aerating thing, it did get completely clear, but is now just slightly cloudy. The water is not green, but I have a little green sediment on the bottom after the filter/pump were off overnight.
I notcied the TA went down, but the Ca went up.
I am going to add the bleach & MA right now.
FYI - The tri-chlor puck has NOT been in the pool.
Do you think I need to do the "keep it up to 15 for several days" thing again? Or just keep on with the normal Chlorine/pH adjustments?
Jennifer
24' round above ground, 13,000 gal
