Thread: First Results ps234
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Default First Results ps234
    Here's the first run:
    FC 1
    CC 1
    TC 2
    pH 7.6
    Alk 130
    Cal 160
    Cya 85
    Temp 73
    Pool water is crystal clear. 10,000 gal pool. I don't close it in the winter and I run the pump/sand filter 24/7.
    Any suggestions from here... last summer my cya was over 110 (wal mart test kit) and I had multiple problems w/ algae and cloudy water. I switched to bleach and the other recommended household chemicals and treated 2x w/ copper sulfate. No more algae, water is clear since I stopped using chlorine sticks. Cya has come down a bit. No longer use algaecide, just bleach and keep ph up w/ borax. Readings have been stable since September 05. Have had NO problems w/ staining or "green hair" so I guess the copper level is down after winter rains, backwashing, etc...
    This web site is amazing. Hope there are no more crashes.
    Any comments on alk or calcium? Seem high to me, but water looks and feels great.
    drband
    Default Re: First Results ps234
    CC is a little high, but I wouldn't worry. Just get your FC up -- with your CYA level, you should think in terms of 'normal' for your pool being between 5 and 10 ppm.
    Otherwise, it's all good.
    Ben
    "PoolDoc"
    drband's Avatar
    Gainesville, GA
    Quote Originally Posted by PoolDoc
    Ben
    "PoolDoc"
    Thanks. Adding bleach tonight. Sure is easier than all the pool store stuff.
    drband
  1. New PS234-First Results
    By lskeate in forum DPD-FAS based testing
    Last Post: 08-09-2006, 02:14 PM
  2. First PS234 results
    By MassAttack in forum DPD-FAS based testing
    Last Post: 07-14-2006, 12:31 AM
  3. First Results from PS234 Kit
    By tnrick in forum DPD-FAS based testing
    Last Post: 07-01-2006, 12:42 PM
  4. PS234 - My 1st set of results
    By kearpaul in forum DPD-FAS based testing
    Last Post: 06-27-2006, 11:56 PM
  5. New PS234 Results
    By jhm in forum DPD-FAS based testing
    Last Post: 06-25-2006, 08:02 PM
