Thread: Can't get the light out!
    May 2010
    Default Re: Can't get the light out!
    Forgot to mention some important facts-- the pool is in ground, plaster, 12,000 gal.
    May 2010
    Asheboro, NC
    Quote Originally Posted by terpsucka View Post
    The secret is the screw shown in the diagram labeled "5". That should be loosened to where it just spins free in that little clip labeled "4". With that done the bezel "should" simply swing out, top first, where that tab you see on the bottom acts like a hinge. With that swing down, the bezel just comes away and then you can remove the sealed portion of the light, the can.
    Now the problem... If this bezel was never removed to replace the bulb, the bezel may have been liberally filled with plaster or shot crete which is stopping the bezel from swinging down on the tab. Too much pulling force and you could break off the tab which would be trouble as in lowering the water level and brazing the tab back on to the outer ring.
    I would start with a snorkel and mask and start tapping the bezel with a rubber mallet to see if it is just 30 years of corrosion and gunk that needs to be loosened up so that the bezel starts to move. With a snorkel you will instantly see stuff coming out around the bezel. If not gunk, look really close for spots that the crete may be touching or behind the bezel and if found, out comes the metal hammer and chisel.
    Instead of a rubber mallet, a piece of wood and a metal hammer will work, Just be careful and patient. If lucky, like I am, the light is under the diving board which can be used to fabricate a makeshift bosons chair. This assumes you have an 8' deep end as I have, if not, it should be an easy task if patient.
    May 2010
    Thanks for all the info Searcher. I was able to pull it back from the top about 20 degrees or so, and when I did that, all kinds of gunk came out, plus alot of black stuff which looked like it might have been dissolved rubber. I don't know whether anyone has ever opened the can; I've lived at the house for 10 years and I certainly never have... who knows what shape that thing is in. Anyway, I will give the rubber mallet a shot when I get home this evening. Thanks again!!
    May 2010
    Ok, I got it out. You were right, there was some gunk in there preventing the bezel from easily slipping off the pin. A little rubber mallet action did the trick!! Everything "looks" normal in there, so it's on to the dye tests.
    May 2010
    Asheboro, NC
    Wonderful! I sure am glad that you posted back to let us know that a recommendation worked.
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  3. pump and light
    By poolhelp101 in forum Pool Equipment & Operations
    Last Post: 04-26-2007, 09:12 PM
  4. What do I do with my light?
    By poolbee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-18-2006, 04:57 PM
  5. Where to put new light?
    By jeffguay in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2006, 07:55 PM
