Results 11 to 13 of 13
Thread: Constant High Chlorine Readings
    Default Re: Constant High Chlorine Readings
    Thank you for the recommendation on the test kit. Unless I'm reading it incorrectly, it looks like the Taylor kit only reads Cl levels up to 5 ppm. Are there kits that read higher, or do I need to dilute the sample to get a higher range?
    Be careful! The Taylor K-2005 kit is a straight DPD test kit that only measures FC to 5ppm. The K-2006 is the one with the FAS-DPD test that measures to (at least) 50 ppm.
  1. High Chlorine readings - how do they impact other readings
    By Charlie in forum DPD-FAS based testing
    Last Post: 02-06-2009, 10:41 PM
  2. Chlorine test readings
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 05:21 PM
  3. Zero Chlorine readings please help!
    By tamil in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-14-2007, 05:44 PM
  4. Can't hold chlorine, all other readings good
    By chipholder in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2006, 02:23 PM
  5. Chlorine and PH readings
    By bxb21 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2006, 04:59 PM
