Results 1 to 10 of 13
Thread: Constant High Chlorine Readings
    Default Re: Constant High Chlorine Readings
    Well, I guess my first question (to myself) is "why am I using a test kit that only goes up to 3 ppm on the Cl reading"? I always assumed that as long as I was above the "ideal" range of 1.0 - 1.5 ppm that I would be OK.
    Sounds like I need to get myself a new test kit and ensure that my Cl is kept at a higher level and then also use liquid Cl along with the tablets.
    Thanks for your help.
    Yeah, the "ideal" range of 1.0 - 1.5 is for an inside pool without CYA, or an outside pool with a very low stabilizer level--but then the chlorine doesn't stay in the pool for long. Since the advent of stabilized tablets, the folks who write the guidelines either have forgotten to update the ranges, or never figured out the CYA/chlorine relationship to begin with--but it's been proven over and over again that as the CYa level rises, so must the chlorine level to be as effective.
    When you manage your pool, a good test kit will save you tons of time, money, and aggravation. We recommend the Taylor K-2006 kit. It can be found online at several different places, but if you get it here http://www.amazon.com/gp/product/B0002IXIIG?ie=UTF8&tag=poolbooks&linkCode=as2&camp %20=1789&creative=9325&creativeASIN=B0002IXIIG"><b >Ta%20ylor%20Complete%20FAS-DPD%20Pool%20Water%20Test%20Kit%20K-2006</b then the Poolforum gets a commission from the order. In the meantime, here's a link http://www.poolforum.com/pf2/showthread.php?t=10073 that describes how to force your kit to measure higher chlorine levels. It's only gonna give you a ballpark, but it's better than nothing until you can get a good test kit.
    I would stop using the tablets in your pool at this point--the CYA will continue to rise as long as you're using it, and when you get to CYA of 100 or so then it's very, very difficulty to maintain a clean, clear pool even with elevated chlorine levels. It's your call, though....
    Thank you for the recommendation on the test kit. Unless I'm reading it incorrectly, it looks like the Taylor kit only reads Cl levels up to 5 ppm. Are there kits that read higher, or do I need to dilute the sample to get a higher range?
    Be careful! The Taylor K-2005 kit is a straight DPD test kit that only measures FC to 5ppm. The K-2006 is the one with the FAS-DPD test that measures to (at least) 50 ppm.
  1. High Chlorine readings - how do they impact other readings
    By Charlie in forum DPD-FAS based testing
    Last Post: 02-06-2009, 09:41 PM
  2. Chlorine test readings
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 04:21 PM
  3. Zero Chlorine readings please help!
    By tamil in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-14-2007, 04:44 PM
  4. Can't hold chlorine, all other readings good
    By chipholder in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2006, 01:23 PM
  5. Chlorine and PH readings
    By bxb21 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2006, 03:59 PM
