Results 1 to 10 of 16
Thread: SWCG Comparison Published
    Default SWCG Comparison Published
    I've just posted a preliminary, but complete comparison between SWCG (salt water chlorine generators) by Auto Pilot, Compu Pool, Hayward, Jandy, Pentair, & SGS:
    http://faq.poolforum.com/products/sa...ators-compared
    If you see errors or omissions, please note them in this thread, so I can correct them.
    PoolDoc
    BigDave's Avatar
    Jul 2010
    New Jersey
    Question Re: SWCG Comparison Published
    Is there a typo in the salt range for the Autopilot and SGS?
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
    Houston.
    Default Re: SWCG Comparison Published
    Hayward has 3 different turbo-cells for 40,000, 25,000 and 15,000 gallons. I'm assuming each have a different output of chlorine. They also have a range of controllers from simple timer to fully automatic.
    Turbo-cell 5 - 15K gallons
    Turbo-cell 9 - 25K
    Turbo-cell 15 - 40K, 1.45 lbs salt/day (I don't know the other two)
    Controllers are aqua rite, pro logic, aqua plus, swimpure. These provide varying degrees of automation.
    Anyone know how to tell which one you have? Edit: Never mind this. I read on the tcell. I have the 15.
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by rpoldervaart View Post
    Turbo-cell 9 - 25K
    Robert
    There are also different software revisions on the controllers so not all units can use theTurboCell 9 or 5.
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by BigDave View Post
    No, Both Autopilot and SGS can operate in seawater but 3000 ppm is the recommended level.
    May 2010
    Great Job Ben. Great Information.
    I know there are quite a few factors that would contribute to this, but is there any chance of something like a 1-5 star rating for these various units based upon Chlorine output, cell life, and other factors (not necessarily cost) etc.? I think maybe a 1-5 scale would be better than a recommended brand.
    I know from my own experience that these SWCG units are not cheap, and I would think that others might benefit from it as opposed to be being "POOL STORED" by their local Pool Store salesman.
    If you can afford a swimming pool and computer, you can probably afford to help keep the PoolForum alive. Please be a responsible member and subscribe today. You'll probably save more than the membership fee on your first trip to the pool store. BTG
    waterbear's Avatar
    St. Augustine, Fl
    Actually, all these units are high quality (with perhaps the exception of the Jandy, which is now owned by Zodiac--but that is a whole 'nother story) so any one of them should perform well. Also this list is not inclusive of all the SWGs on the market and there are other excellent ones that are somewhat common such as WaterMaid and Resiliance that are not on the list.
    Ft Lauderdale, Fl
    The SGS Owners Manual shows that 8000 ppm is too high for salt and should not be exceeded "to avoid damage to the SG "Series" system. It conflicts with page 8 that shows a special application high limit of 35,000 ppm.
    http://sgschlorinators.com/wp-conten...anual-2010.pdf
    Resilience is not currently available, as the manufacturing company in Israel is no longer in business.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    May 2011
    Coral Springs, FL (SE Florida - near Fort Lauderdale)
    Quote Originally Posted by waterbear View Post
    What's wrong with the Jandy units? I am considering the AquaPure Ei to control with my AquaLink OneTouch. Would love to hear some input. The rest of my Jandy system has been great for years (well, aside from that lightning strike, but can't blame Jandy for that). Thanks!
    My pool:
    15x30 inground concrete pool w/spa in one corner overflowing into pool, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter
    Jandy Laars LX400 propane heater w/120 gal above-ground tank
    Jandy AquaLink RS OneTouch controller w/PDA remotes and computer control
    JVAs control pool/spa switch and also allow drain opening
    Hayward Navigator
    Apr 2011
    Is the Compupool 60 susposed to be the CSPC 48?
    17K IGP, CSPC 48, Pentair CC100 Cartridge filter, 1HP DuraGlas II,
  1. Pool Comparison
    By Jacob99 in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2011, 11:58 AM
  2. Comparison of Plasters
    By stuckpipe in forum In-Ground Pool Construction and Repair
    Last Post: 02-05-2011, 10:28 PM
  3. heat pump comparison
    By wilcfr in forum Pool Equipment & Operations
    Last Post: 08-03-2009, 05:08 PM
  4. shock to bleach comparison
    By Renee C in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2006, 10:18 AM
