Thread: Raypak RP2100 Service Light
    Aug 2010
    SoCal
    Default Raypak RP2100 Service Light
    My 10 year old Raypak RP2100 service light went on and will not heat up. I opened up the panel to view the circuilt board and see a red led lit.
    The board shows:
    OVERTEMP {LED} SENSOR {LED} FAIL
    The led between SENSOR and FAIL is lit. I'll take this at face value and consider some kind of sensor has failed but which one and how to confirm which one. Is there a way to short the sensor leads or do some 'trick' to let the circuit board know all is ok to lit?
    This happens as soon as the unit is turned on so it is not possible for an over temp situation. This happened last week and I could swear that both LED's were lit but today only the 1 LED is lit.
    I did several Google searchs and did not find anything. We must have an 'old' version since most postings had to deal with a display panel that will show error codes but my panel has no such display, only the rocker switch and lights.
    May 2010
    Default Re: Raypak RP2100 Service Light
    The sensor (mounted on the inlet / outlet header), is done. You will need to replace it. Thats the way it has been, for me.
    Now, i suppose that the plug (on th circuit board), could go bad, I just haven't ever seen it. I have changed maybe 10, over the years. A very reliable sensor IMO.
    Note: There may be a chart in your owners manual that will list various resistances to temperature, if you wanted to test the sensor with an ohm meter.
    Did that make any sense?
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    Aug 2010
    SoCal
    Which sensor? There is a sensor on the INLET with 3 wires (2 red, 1 black) and there is another sensor on the side of the OUTLET. There are only 2 wires on the outlet sensor with spade connectors.
    By the way, I just checked this and now the other LED light is on (between OVERTEMP and SENSOR). Before, only the LED between SENSOR and FAIL was lit. Do you know what each ones of these mean?
    Aug 2010
    SoCal
    My replacement temperature sensor showed up today and I installed it. I still get the same error lights. Any help?
    May 2010
    What i have been told (from Raypak) is that when that light has come on, its that the board has experienced and over temp condition, not water temp, but probably a voltage problem within the board. Unfortunately the board is done, and will need to be replaced.
  1. Raypak RP2100 Service Light
    By FrankieD in forum Pool Equipment & Operations
    Last Post: 10-20-2011, 10:17 AM
  2. Raypak RP2100 Shutting off
    By CaptNemo in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-26-2011, 09:53 PM
  3. RayPak and Intellitouch i5
    By dchango in forum Pool Equipment & Operations
    Last Post: 10-23-2010, 11:31 AM
  4. Raypak RP2100 SNS code need help?
    By shutitdown in forum Pool Equipment & Operations
    Last Post: 06-01-2009, 12:32 PM
  5. Raypak Gas Heater
    By rjarvis in forum Pool Equipment & Operations
    Last Post: 04-24-2008, 09:51 PM
