Thread: clorine and algacide
    Default clorine and algacide
    Can I add algacide when I add the clorine to my inground pool? I don't want to cause any problems with the chemistry. Or should I wait until the next day. I would like to keep on top of the algae before it develops. Also would you recommend the algacide weekly? I'm new at this!
    Default Re: clorine and algacide
    I don't think it matters if you add it with the chlorine or the next day. But, you don't really need to add any algaecide at all. If you maintain proper water chemistry, you don't need it. I never use it except for when I close the pool in the fall. Just testing your water regularly and making sure you maintain adequate chlorine levels will keep algae from developing. Hope this helps. BTW - welcome to the forum.
    (I am going to move your post to the testing and adjusting water chemistry forum instead of here. This forum is actually for questions about using the forum itself.)
  1. huge clorine demand
    By sabres07 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2013, 02:22 PM
  2. Chlorine Disappearing in Outdoor Pool
    By virgoglo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-17-2012, 01:11 PM
  3. Clorine Block - Need Advice
    By kevinob in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-07-2011, 02:49 PM
  4. Free Clorine
    By thewalk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2007, 09:54 PM
  5. Clorine Lock
    By Bmushal in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-07-2006, 10:20 PM
