Thread: pH levels -- they won't stay down
    Default Re: pH levels -- they won't stay down
    Until the plaster is fully cured (and that could take as long as a year) you are going to have a very high acid demand. As the plaster cures it will leach out alkaline material into the water. It is the nature of the beast, unfortunately. Keep up with the testing and the additions of acid as needed and do not let the pH spike high if you can avoid it. This will insure proper curing of the plaster with minimal chance of scale formation.
    (THIS is one of the main reasons I chose fiberglass for my own pool!)
  1. PH won't go/stay up
    By GAPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 12:40 PM
  2. Pool heater won't stay lit!
    By Rob311 in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 09:38 PM
  3. pH, what should it be? How long can I let it stay how low? Where should TA be?
    By DistantHorizon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2011, 10:30 PM
  4. Chlorine won't stay in pool
    By LVpool in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-21-2011, 05:46 PM
  5. I BBBed my hot tub , but it won't stay
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2006, 04:06 AM
