After searching through the posts, I'm not seeing this specific problem, which is: at startup the pool pressure gauge showed normal pressure, and there were no bubbles from our returns. Now we're seeing large bubbles from one return, tiny ones from the other (closer) return, and the pressure gauge has dropped significantly. I've replaced the pump basket O-ring, and tightened all the fittings and various plugs. No change. Any ideas as to what to check now? By the way our pool was just remodeled, and has a new skimmer. The water level is not dropping either. All suggestions will be greatly appreciated.
Also check the wtrer level and skimmer weir.
