I recently purchased a house with a 3 year old inground pool and a salt system. The control panel from the salt system had to be replaced (black burned cap, and I didn't want to risk just replacing that and damaging the extremely expensive cell). I replaced that and the system shows "check cell" flashing and low salt. The system shows 2200ppm and wants 3200. When I get my water tested at the pool store they pretty consistently get 3000ppm (last time it was down to 2800, though) and tell me I don't need more salt. I visually inspected the cell and I don't see any scale buildup, there was some debris in there that I cleaned out. Took the cell to the pool store and they tested it and said it was working fine.
I was thinking of adding salt to get the system to read 3200, but how do I calculate the proper amount of salt to add for 12,000 gal pool to increase 1000ppm?
I've had the cell on 100% and the pump running 8h a day and chlorine levels continue to drop; perhaps it's generating some, but not "enough".
The cell (in fact the whole pool) is only 3 years old and the place was vacant for 7 months so the cell has only been run for 2 seasons; I'm hoping to avoid replacing it. Any suggestions on where to proceed other than my theory about increasing the salt until the cell says it's happy at 3200?
latest water test:
TC: 2.5 ppm
FC: 2.5 ppm
CC: 0 ppm
pH: 7.8 (I added 1.5cups muriatic, and haven't retested yet)
AD: 1
TA: 110 ppm
CH: 400 ppm
Sta: 90 ppm
TDS: 4200 ppm
Salt: 2800 ppm
I read some other posts about testing the cell, and I might try the "drip" method, but the salt system is definitely a slave to the pump so I can't do the bucket method.
I'll give the cell another good washing tomorrow (after I come up with some kind of large toothbrush or something for the inside. Unfortunately I can't find the site I thought was selling the cells for 300 bucks so it appears I'm on my way to another $500 purchase unless I get lucky with cleaning this thing.
