Thread: Can't get CYA levels up
    May 2010
    107 Baldwin Terrace
    Default Can't get CYA levels up
    I have an 18' round AG pool with 54" walls.
    I have added a full 2 lbs of CYA using the panty hose tied in front of the return jet method.
    Pump/filter have been running for 3 days; 24 hours a day.
    I have tested water 3 x using the Taylor K 2006 and can not get the CYA levels to go up at all. My water is sparkling clear, but I think it's because I'm dumping in ~1 gallon every other day of Chlorox.
    Is it possible that my jug of CYA was bad? Help? TIA!
    Default Re: Can't get CYA levels up
    Sometimes it takes up to 4-5 days before the CYA registers in the water. Is all the CYA in the pantyhose dissolved?
    2 lbs of CYA will raise your 7200 gal pool to 30 ppm which is the lowest that many tests can measure. I would add another half pound (scant half cup is close) to bump the level up slightly in case your test is just not registering it.
    Wait a week until you test for it since sometimes it does take a while to show up and be sure NOT to backwash from the time you add until you test to be sure not to accidentally backwash it away.
  1. cya and other levels
    By dalejanus in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2012, 12:25 PM
  2. Help with getting levels right please!
    By one4irish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2010, 03:02 PM
  3. CA levels
    By wilcfr in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2008, 12:07 AM
  4. CYA Levels
    By hooeld in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2006, 09:17 PM
  5. CYA and FC levels with SWG
    By mizzouguy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-24-2006, 10:30 PM
