Thread: grate/cover for the bottom of the pool
    Jun 2010
    Phoenix, Arizona USA
    Default grate/cover for the bottom of the pool
    All,
    I have learned a lot from everyone at this site. I have a couple of quick questions and the answers might help me solve the problems with my pool vacuum.
    First, what is the grate at the bottom of the pool called? Is it a return grate? Is the purpose to have a second point of suction in the pool?
    Second, I have seen different covers? Why would someone need these? How do you replace them? Would the grate be the reason that my pool vacuum sticks at the bottom every time it passes by?
    Thanks,
    Guy
    Default Re: grate/cover for the bottom of the pool
    The grate covers what is typically called the "Main Drain" in the pool. Your pump pulls from this and from the skimmer(s). Some pools now have two main drains to prevent a kid from getting sucked in if they block one while playing around. There are special covers that can go over it to prevent pool cleaners from getting stuck.
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. Cemented Main Drain and wall grate questions
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-27-2010, 12:32 PM
  3. Solar cover and black-bottom IG pool
    By dafletcha in forum Pool Equipment & Operations
    Last Post: 09-10-2006, 11:12 PM
  4. Pool safety cover. "The Hugger Cover"?
    By chrisinaz in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 10:32 AM
