Thread: Tree branch smashed my piping :(
    Default Tree branch smashed my piping :(
    Woke up Friday morning and when I went outside I did not hear my pump running. During the night a 4" wide tree branch came down and smashed the piping between the pump and the multiport valve, and also cracked the pipe at the pump inlet. Fortunately for me the Intelliflow pump sensed this and shut down.
    A trip to the Homedepot and an hour of sawing and gluing and I am back up and running. Turns out it was a good thing. I always had air in the pump basket when the pump was running under 1,100 RPM. No bubbles in the returns just the basket was not full with water. Turns out the threads on the 2" inlet must have been leaking some air, as now the basket is totally full.
    Honesdale PA
    Default Re: Tree branch smashed my piping :(
    You're lucky the threaded pump inlet didn't crack. Good work.
  1. Backyard with lots of tree, what're my options?
    By Anthonyhomer in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-30-2013, 02:03 PM
  2. Fun with a Mesquite tree
    By BadDog in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 01:50 PM
  3. Tree stumps....
    By court475 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-11-2006, 01:25 PM
  4. Tree Roots
    By sw_stupid in forum In-Ground Pool Construction and Repair
    Last Post: 05-14-2006, 10:04 PM
  5. Oak Tree Flowering
    By donfranko in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-26-2006, 10:46 PM
