Results 1 to 10 of 22
Thread: Above ground pool question....you don't even want to know why!
    Default Re: Above ground pool question....you don't even want to know why!
    I've had 9-12" of ice in my pool over the winter. I don't have to try ice fishing like Al ( ) because there's always a gap between the ice and the pool wall. I DO try to keep the winter fish out of my pool....
    Red face Re: Above ground pool question....you don't even want to know why!
    Okay, here's another question. I need to plug the main drain in my pool. After much research, I won't be using it for the pond.
    I do not own scuba gear, nor do I know what I will be seeing once I get the main drain cover off. So......does anybody know what the internals of a main drain look like? The pool store guy said there should be two screws holding the main drain cover on. Once I get those out, I should see a 1.5" PVC pipe coming in from the side. He said to just use one of those rubber, expandable type plugs to plug it. I was hoping something threaded would work. Thought that might be more water tight. He didn't know if there would be threads or not.
    Either way, I need to be able to sink down 6.5 feet, unscrew two screws, plug the pipe, and screw the cover back on without an air tank. I know I can make several dives and not have to do it all in one. I am thinking of trying to just use a garden hose to breathe through (like a long snorkel) and trying to rig up some kind of weight to keep me down easier. Maybe I could just have my husband keep me down with the vacuum pole.
    No wise cracks, please.....I know I'm asking for it though! Any suggestions would be appreciated! I definitely don't want to drain the pool...that would be bad for the liner and a waste of water. And I'd rather not hire somebody if I can manage this on my own, which I think I can.
    Thanks,
    Sandy
  1. Question about above ground pool vac and pool pump timer from newbie.
    By momtoallgirls4 in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 01:06 PM
  2. New Above Ground pool question
    By turnerg in forum Pools, Pets and Creepy Critters
    Last Post: 06-27-2012, 06:14 PM
  3. Above ground pool light question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 09:04 PM
  4. in ground vinyl liner question
    By dweer in forum In-Ground Pool Construction and Repair
    Last Post: 05-23-2012, 04:36 PM
  5. Above ground pool Filter Question
    By UNITY520 in forum Pool Equipment & Operations
    Last Post: 05-08-2012, 10:24 AM
