Thread: Light Source for Reading pH Test at Night
    Phoenix, Arizona
    Default Light Source for Reading pH Test at Night
    Hi All --
    I think it's safe to assume that natural light is ideal for reading the pH test, and I try to test at dusk, but that doesn't always work out. What light source do you folks use when reading the test at night?
    Also...I've heard that men in particular can have trouble distinguishing the shades of pink/purple and I'd have to say that I fit into that group, especially when trying to read the test with any kind of indoor lighting. Any "tricks" that you use to make it easier to read?
    Thanks!
    Scott
    Default Re: Light Source for Reading pH Test at Night
    Sunlight with a white card behind it. I sometimes find a white cloud. Certain fluorescent lights may work. Be careful: they come in different shades and ones listed as "daylight" may be nothing of the sort.
    Many men do have troubles distinguishing colors, after all color-blindness is almost exclusively a male disorder--I don't think I've ever heard of a color-blind woman.
    However, I wonder if some of it is training. There are techniques to detect very fine differences. I did some painting in college and mixing, or worse, re-mixing the perfect color is something you learn to do. But, after all, who usually determines which paint chip or tile color is exactly right?
    I'm lucky, I guess. i have no trouble distinguishing faint differences in tints. What I find hard is when the tint of the sample deviates from the colors on the cell, for example having a purple hue in the water when the pH cell has none.
    The oddest thing: My wife had a friend whose brother painted religious icons--they were fabulous and nobody knew how he did it as he is totally colorblind--monochromatic, and only sees in black, white and gray. Yet he used color like a master.
    I use either a cloud for the background or the flourescent light in my kitchen. It's actually easier for me to read it with the light than in bright sunlight.
    Lehigh Valley, PA
    For those times when I test after dark I use a GEPE light box.
    It provides 5000K color corrected light, runs on batteries but also has an AC adapter.
    This allows me to do the testing poolside without having to hike down the hill to the laundry room.
  1. To run day or night?
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-04-2013, 12:04 AM
  2. need help reading cya results from K-2006 test kit
    By Kateyru in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-05-2012, 03:17 PM
  3. My Night Mare
    By JeffB in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 09:32 AM
  4. Having difficulty reading PH test / PH is not stable
    By vanduse1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-15-2006, 01:10 AM
  5. I shock at night, but sometimes...
    By Tyrone Shuz in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2006, 02:32 AM
