Bud,
What's your pool type and volume?
Ph and alk look great, don't see calcium listed (not important for vinyl pools unless you use a heater).
I'd stay away from any more di-chlo or tri-chlor products (granules or pucks). They will add more CYA to your pool, which will diminish chlorine's effectiveness. Your chorine level of 5 is not too high, with a CYA of 80, it needs to run smidge on the higher end. Stick with bleach and you'll be fine.
CaryB
