I have a timer turn the pool pilot on/off. The pool pilot is controlling the 2 spd pump. The poolpilot really never turns the pump off, power is always applied. The program allows you set pump times. Example: Timer comes on at 5:30am pump runs on low speed. Pool pilot pump 1 program set for 6:00am to 7:00 the pump runs on high, then pump ruturns to low speed. Pool pilot pump 2 program set for 5:00 to 6:00pm pump runs on high, then pump returns to low until the timer shuts off at 6:30pm.
The Poolpilot is not capable of a true 2speed control with both off. Just allows you switch between speeds.
I just have a Intermatic 220V timer.
