Results 1 to 10 of 12
Thread: Eye irritation with 7.5 pH and 0 CC?
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Default Re: Eye irritation with 7.5 pH and 0 CC?
    I'm constantly amazed by the info I find here on the forum! Thanks for answering this... I've had the same question for a while...
    Ontario.
    How do you increase the TDS if it is low? I have a vinyl pool and have always ignored TDS.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Add salt.
    Many pool owners add enough to reach around 2000 ppm and report a increase in bather comfort. There has been discussion about this in the past on the forum and on other forums and I don't remember anyone ever regretting adding salt.
    May 2010
    Can you post the rest of your readings, like CYA and FC for starters?
    Attaching Chem_Geek's papers:
    Effect of saline on the eye irritation caused by swimming-pool water, 1973
    Fluorophotometric measurement of pH of human tears in vivo, 1997
    http://www.ncbi.nlm.nih.gov/pubmed/9154387
    Ben
    Ontario.
    Add salt.
    That's 2000 ppm of salt, not a TDS reading?
    Apologies if I am re-treading old ground. When I search for TDS, it's to short to be used by the search function.
    Quote Originally Posted by Spensar View Post
    That's correct.
  1. Salvation Army Pool eye irritation
    By SalvationArmy in forum Commercial Pool Users, Managers & Workers
    Last Post: 06-27-2011, 10:55 PM
  2. Does perfect CL levels mean no irritation to eyes?
    By rastoma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-19-2006, 09:41 AM
