Re: First pool, might be our LAST...name says it all!
Today: added 1 cup bleach @ 10am, another cup @ 3pm. Took new filter out and flushed it (noticably not as bad as the first filter..)
Here's the GOOD NEWS!...the water is a little clearer this evening, we can actually see the 2nd step on the ladder!! whoohoo!!!!!!!!
6pm test results: (HTH 6-way test kit from Wallmart)
CL: below .5 (I'm guessing you'll tell me to add more..)
Ph: 7.3
Cya: Black dot never disappeared
Alka: 190 ppm
Hardness: 120 ppm (test water never turned "red", only purple...took 12 drops to turn from purple to blue)
A neighbor stopped by who has a larger pool, said to add "stabilizer".....I told him I'd have to check with you FIRST! Yes? No?
