Results 1 to 10 of 60
Thread: First pool, might be our LAST...name says it all!
    Nevada
    Default Re: First pool, might be our LAST...name says it all!
    ok...I'm breathing again. I'm going to have FAITH that you all can turn this mess around.
    Testing - we purchased a small drop test kit when we bought the pool, it only tests for CL/BR and PH (didn't think we needed to be concerned with anything else..ha)
    Update: put in new filter last night (not bad, one day = one filter) as it was BLACK, added 12 oz of hth metal control and ran pump all night long. Tested this morning:
    CL 2 to 3 range
    Ph 7.2
    This morning I was headed to pick up bleach as I've read here...(ok, from this post on we'll only add or do what YOU tell us..) is it ok to switch to bleach after using so much of the shock? I figured at this rate the pool is becoming a chemical pool anyhow, right? (sorry, sarcasim.) I realize the staining is the least of our problems...well, maybe my children don't think so, one time in the pool has ruined their bathing suits and I think given them a deeper tan. I do have one with sensitive skin so I'm concerned for her.
    While in town (we live 20 miles out in horse country) I'll buy a better test kit too, Walmart is really my ownly option other than a pool store. Oh, and just so you know we're not compete morons, we never EVER considered putting up a pool knowing about our water until the local public pool closed this year due to budget cuts. : (
    Thanks in advance for your help!
    Switching to bleach is no problem. All chlorine is chlorine once it's in the water. You just cannot mix them together--like pouring bleach over Cal-Hypo powder or Tri-chlor tablets is a really, really bad idea! (don't ask why--just don't do it.)
    You can read higher amounts of chlorine (ignore the bromine) with your tester by diluting the pool water with steam distilled water (avail at your supermarket). If you dilute it one to one, you can double the reading you get. Use 2 parts distilled and 1 part pool and you can triple the reading.
    I like to use a shot glass to measure because it's simple, easy, and very accurate.
    Nevada
    Today: added 1 cup bleach @ 10am, another cup @ 3pm. Took new filter out and flushed it (noticably not as bad as the first filter..)
    Here's the GOOD NEWS!...the water is a little clearer this evening, we can actually see the 2nd step on the ladder!! whoohoo!!!!!!!!
    6pm test results: (HTH 6-way test kit from Wallmart)
    CL: below .5 (I'm guessing you'll tell me to add more..)
    Ph: 7.3
    Cya: Black dot never disappeared
    Alka: 190 ppm
    Hardness: 120 ppm (test water never turned "red", only purple...took 12 drops to turn from purple to blue)
    A neighbor stopped by who has a larger pool, said to add "stabilizer".....I told him I'd have to check with you FIRST! Yes? No?
    The test kit that we favor here is the Taylor K-2006, which can be found online at http://www.amatoind.com/, http://www.spspools-spas.com/, or even better at http://www.amazon.com/gp/product/B00...SIN=B0002IXIIG (PF gets a contribution from them if it's ordered here). You can also get the same basic relabeled kit at Leslie's online stores. I know they're a little pricey, but I guarantee you the kit will save you hundreds of dollars just this summer alone (and they don't cost more than what you've already put into your pool!).
    After adding the metal control, how does the water look? Can you tell any difference?
    I typed my previous post while your last one was waiting to be modded in, which is why they're in reverse order. Anyway.......
    It's good that you're seeing some improvement. You may need to add some more of the metal out until the water starts clearing. In the meantime, keep your chlorine at the 2-4 range, your pH on the low side, and keep changing your filter as needed. (You're right, add some more bleach!)
    You don't need to test for CYA again until about 4-5 days after you've added stabilizer. You can get it at WalMart in a 4 lb container. I don't remember if it's labeled "balancer", "conditioner", or "stabilizer", but the important thing is the active ingredient is cyanuric or isocyanuric acid. Follow the label directions for the amount to take your pool to the 40 ppm target, but then only add about 1/2 that amount, because it's much easier to add more later to get to your target than it is to have to drain/refill water if you overshoot. Because you're having to constantly change your filter, I would add it by putting it into an old sock or knee hi hose and hanging it in front of a return. It dissolves slowly, so don't add more or retest for it for about 4-5 days after you add it. The stabilizer will protect your chlorine from sunlight, so that it can be more effective against stuff in your pool. You should be adding chlorine a couple of times a day to keep a chlorine residual in the pool--once the stabilizer is in the water, then you won't have to add it as often.
    Nevada
    Janet, WOW! you're awesome!
    I added more bleach tonight (5 cups!) and will also add some more metal out and let the pump run over night again. It was very windy here today, does that help drain the chlorine? because I was very surprised by the reading.
    I'm printing out your instructions, hubby will run to the store in the morning for the Cyanuric/Isocyanuric Acid.
    Thank you!
    Don't worry about T/A or hardness for now. Keep your pH in the 7.2-7.5 range and keep up your CL level.
    Because you may have a metal issue, Jan doesn't want you to raise your CL too high. Otherwise, we'd be telling you to hammer the pool with chlorine.
    Meanwhile, keep hosing down those filters! While I know Intex filters aren't too expensive if you change 'em every 2 weeks, but every day can be. Meantime, if you think one's ready to chuck, try soaking it in electric dishwasher detergent, like Electrasol. The people with large cartridge systems where the filters cost triple digits do that all the time. I'm not sure of the amount of detergent, but you can do a search on our forum to find it.
    Meanwhile, if Chem_Geek pops in, he is a cart filter owner and can probably suggest how to get more life from your filters.
    I have an oversized 4-cart filter (a Jandy CL350) for my 16,000 gallon pool and that lets me clean it just once a year, but I have a pool cover that keeps the pool relatively clean. I still clean it the filter the same way as others, hosing them off and then soaking in detergent. I just replaced mine recently after about 6 years, mostly because the straps were coming apart -- something I could have manually fixed but decided to just get new filters.
    Nevada
    Good Morning! (or afternoon..I'm in Nevada on Pacific time)
    Thank you CarlD & Chem geek...
    I stayed up until 1:30am soaking up as much of this forum as I could, I took 5 pages of notes and learned alot from others mistakes/questions/answers...so hopefully I can fall into line quickly.
    7am (6-way HTH test kit)
    CL: 2.5
    Ph: 7.2
    Alka: 180 ppm (tested before reading CarlD's post...I'm assuming that's what TA means,
    Total Alkaline)
    Hardness: 100 ppm
    Pump ran all night, I flushed the filter with water again and scrubbed the skimmer basket clean (used Greased Lightning degreaser and rinsed with water..worked fabulously, it also cleaned up the pump which was horribly stained with my fingerprints...might discolor with time, it contains Alkaline and Surfactants ? I wouldn't use it IN or ON my pool, so don't think that!) then added 2 cups bleach (slowly, into skimmer) ...see, I learned something last night.
    This morning when I ran my hand through the water I noticed I could SEE MY HAND! (pauses to measure arm length...) THAT'S 27 INCHES!!! It's getting better folks!
    But then, why do I think you knew that would happen....
    The neighbor who stopped by yesterday (he's had an 18x48 Intex for 2 years) confirmed that his water looked exactly the same upon filling (we're on the same well water field.) He proceeded to tell me everything I needed to do..but when he pulled out his test strips I immediately TUNED HIM OUT! hehe I did however perk up when he said a stablizer cleared his water. At Aylads' suggestion, my husbands in town picking some up right now (cyanuric or Isocyanuri acid.)
    I'll post results again tonight...thanks all!
    Nevada
    side bar - I felt inside the pool, the walls don't feel slimy just nice and clean.
