Have you been adding baking soda to increase your T/A level?
Normal T/A levels are from 80 to 120ppm and you are low at 70. Ordinary Arm&Hammer Baking Soda (or generic) is the same stuff they sell as "Total Alkalinity Raiser".
You are adding MA to lower pH--that's normal. But you are bringing down your T/A with it and the aeration of your water (do you have a waterfall or fountain?) is, via the out-gassing Waterbear mentioned, probably what's driving your pH back up.
So you add more MA...and it takes your T/A down some more.
I'm not sure how to stop the out-gassing other than turning off fountains, waterfalls, pointing the returns DOWN so they don't roil the surface--and maybe using a solar cover when you aren't swimming. But Waterbear may have better suggestions for reducing it.
Meantime I'd get the T/A back up. If you have a vinyl pool you may consider raising it higher. If you have a concrete/plaster pool, you may want to just take it to the upper range. Again, all you need to do this is baking soda.
Again, Waterbear may offer a reason not to do this, but that's usually how we get pH to stop oscillating, unless, of course, you have another cause of the rising pH.
