Re: type of sand
Watermom
Anna,
I'm glad you have been happy with your pump/filter set up. A 1-1/2 hp pump is a BIG pump for a 12,500 gallon pool. Overkill really. My pool is about the same size. I initially had a 1hp pump but it was more than I needed. When I changed it a few years ago, Poconos (our resident pump expert) selected a 1/2 hp inground full-rated pump for my pool and it has been fine. Saves me energy costs and is plenty pump for my pool. I also have a 200# sand filter. I have never had to change anything in my filter. The fact that you are having to change your spider gasket every year makes me wonder if the big 1-1/2 hp pump is damaging your filter. I dunno. I'm not the pump expert around here. Just wondering.
The pump runs on the LOW setting nearly all the time except when I vacuum or backwash rinse. LOW settings on a 2-speed pump use 1/4 of the power as do single speed pumps. I'm no math wizard and don't know if the relationship is linear but it's possible that this setup uses less energy than a 1-speed 1/2 hp pump does.
Spider gaskets are inexpensive and we don't mind doing the maintenance. We look at it like we do oil changes on the cars: every 2,500 miles, whether they need it or not
