Thread: Losing Chlorine
    May 2010
    Default Losing Chlorine
    This past week I have started losing my chlorine it is 0. I have been putting in 10 gallons every 2 days in the evening and the next day it's gone by evening. Had been doing good for a month. The water is clear. Inground 20X40 vinyl around 50000 gallons.
    TC 0
    FC 0
    Ph 7.6
    Alka 120
    CYA 40
    Default Re: Losing Chlorine
    Quote Originally Posted by hannadock View Post
    TC 0
    FC 0
    Ph 7.6
    Alka 120
    CYA 40
    10 gallons of bleach on a typical 20x40 vinyl with deep end is about a 20 ppm dose of chlorine. (Gallons on straight rectangle vinyl pool are typically 30,000).
    How are you testing? It needs to be with OTO -- the cheap test kits all use this, and it turn yellow to dark orange in the presence of chlorine.
    Given the dosing you are doing, it's quite possible that your chlorine is so high it's bleaching out your chlorine test. OTO won't bleach out, so test with that.
    PoolDoc
  1. losing my chlorine
    By mmcinnes in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-06-2012, 08:45 PM
  2. Losing chlorine
    By joecus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-07-2010, 06:40 PM
  3. Almost Losing Prime...Gurgling Sand Filter...Switch to Chlorine
    By tmbier in forum Pool Equipment & Operations
    Last Post: 08-24-2006, 11:13 PM
  4. Do I need to shock if losing chlorine?
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 01:51 PM
  5. Help! Losing h20
    By timthompson in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 12:42 PM
