Results 1 to 10 of 10
Thread: First Timer Ready to Fill, Could use some help
    Default Re: First Timer Ready to Fill, Could use some help
    Quote Originally Posted by jkoch View Post
    I have 1.5 lbs CYA in sock in front of return.
    That is not going to be enough to even test for in 12k gal. Why not take
    watermom's advice above and use 3lbs. You can pour the other 1.5 lbs directly into your skimmer if you have one, with the pump running. You will need to get three pounds in there to really have enough in the water to be able to test it.
    Edit: Seems watermom and I were posting at the same time! twisted minds think alike!
    Jun 2010
    Thanks, I'll get more CYA. Can I just dump it into my skimmer? I have a sand filter.
    Also, Should I leave cover on or off?
    Yes, you can dump it in the skimmer. Just don't backwash for a week to give it plenty of time to dissolve. I usually run my pump 24/7 for the first couple of days after I put cya in the skimmer. I don't think it matters one way or another about the cover.
  1. About ready to fill my pool full of dirt!!!!
    By sbillingsley in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-26-2012, 10:16 PM
  2. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 07:00 PM
  3. Getting ready to dig it up - talk me out of it.
    By Miataguy in forum In-Ground Pool Construction and Repair
    Last Post: 12-10-2006, 08:57 PM
  4. So, am I ready to ROCK???
    By Pool_Mike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-22-2006, 11:01 AM
  5. Getting the Pool Ready
    By TJNav in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-26-2006, 01:40 AM
