Finally have 24' Round vinyl pool set up and ready for water. I have Taylor Test Kit.
Due to Well and lots of Iron I am going to fill thru me Softener. Should take 2 to 3 days with fill time, regeneration and sleep considered.
My Numbers from tap prior to fill:
Capacity: 12,500 Gallons
CYA: 0
Free Chlorine: 0
Tot Chlorine: 0
pH: 7.6
TA: 241
CYA: 0
So, I guess I will add approximately 3 quarts of Bleach ( 6% ).
Add 4 lbs of CYA.
11 oz of 20 Baume Muratic Acid to Lower my Alkalinity. (But with that goes my ph down. Possibly aerate to help bump up my PH.)
Can someone help me with the sequence of this? Anything I am missing?
Do I gradually add the Chlorine? When do I add the Muratic Acid and the CYA?
Keep in mind this will all take place over a 2 or 3 days and my pump will not be on for the first day for sure.
Your help is greatly appreciated. I really hope to get ahead of this and not have to catch up with problems by doing it right the first time.
Thanks a bunch in advance,
JK
